Knocking noise
I have an 06 Chevy Aveo. Several months ago I started intermittently hearing a noisetgat I can best describe as a knocking noise. It happens at various times but tends to happen most when I am idle. At times it appears to be coming from the lower driver side other times it appears to be coming from the engine. Recently the noise has become quite frequent.
When I took my car in for an oil change I asked the mechanic if he could listen for the noise and tell me what he thought it might be he stated my car was low on oil and that that was the reason for the noise it has been several weeks since then and the noise is still continuing.
I made a video of the noise and uploaded it to YouTube I am posting a link below can anyone tell me what they think the noise might be?
https://youtu.be/Dmot_pXAXSY
Answers
In case they are adjusted automatically, then the noise indicates lifter or camshaft lobe wear.
I don't have the specs on a Chevy Aveo (which I believe has an engine made by Daewoo).
Since it seems to be a singular noise (one valve lifter or cam lobe) then low oil probably wasn't a good guess by the mechanic.
