2012 Hyundai Sonata oil issue
Hi all,
This is a four cylinder limited edition...the oil disappears with no leaking or smoking.
Has anyone heard of this happening ?
Looking for a recall bulletin with no success yet. Any help is appreciated.
BTW: No warning lights go on for an alert, no drips in the drive and no smoke upon rapid acceleration.
Nate
Nate
Answers
Does your car have about 70,000 miles? That is usually when the PCV valve fails and causes oil blowby into the engine combustion chamber.
PCV valves cost under $10 and take five minutes to replace with a pair of pliers.
YouTube has videos showing the procedure.
I just put a top brand synthetic in it and instead of topping off about a quart every 5-6 weeks or so, it was reduced down to maybe 1/4 quart every 2 months which is a huge improvement. The engine was just one of those engines that burned up oil for whatever reason and there was no recall no solution...
worth a try, here it is for your specific make and model,
https://searchforparts.com/oil-change/hyundai-2012-sonata-2.0l-b
yes I see that this is an old thread but I just wanted to post for future reference and for current readers who may have the same problem, you can look up your vehicle on the site above for the amount you will need in quarts, the filter to go along with the synthetic, and the type of oil.
