electrical problem 2006 acura tsx
i have a 2006 Acura TSX. when i purchased the car the left low beam headlight did not work. we replaced ballast, ignitor switch now left low and highbeam work . problem now right low beam not working… and battery drained every morning
Best Answer
Mr_Shiftright Member Posts: 64,481
You'll have to put a test light on the right low beam connector to see if it's the bulb or not. The battery drain can be check by doing a "parasitic drain test" which you can learn about on YouTube--there are some good ones by Eric the Car Guy and South Main Garage.5
