FUEL SYSTEM/PATS
Andyg_37Andyg_37 Member Posts: 5
edited January 2019 in Lincoln
PATS SYSTEM ACTIVATED, JUST REPLACED ECM AND STEERING COLUMN.TOOK TO DEALER TO HAVE KEYS MESHED WITH ECM THEY CLAIM THEY GOT ECM PROGRAMMED BUT CAN'T GET OTHER PART TO PROGRAM. THEY SAID FOR ANOTHER $300 THEY CAN TRY AND IF THAT WON'T WORK THEY SAID ANOTHER $1000 WOULD GET IT DONE. SO IS THERE ANY WAY TO TWIST ANY PATS WIRES TOGETHER TO MAKE IT WORK ? THE PATS HAS DISABLED MY FUEL SYSTEM CAN I RUN CONSTANT POWER TO FUEL PUMP ? WILL THAT WORK?? ANY HELP IS APPRECIATED
Best Answers
  • Andyg_37Andyg_37 Member Posts: 5
    Answer ✓
    Online order from Texas all codes on ecm matched exactly.
    Answer ✓
    Where did you get the ECM?
    Ordered online all code numbers matched
    Answer ✓
    Anyone have a solution to this? Someone told me to "ground out the PATS system under the hood"
Answers
