numerous issues
Kerry17Kerry17 Member Posts: 1
edited February 2019 in Jeep
99 jeep cherokee classic 4.0 started out running rough bucking and jerking . have changed crank position sensor , plugs wires disrtibutor cam position sensor . cleaned throttle body fixed some wires . now it will drive then stalls and wont start back up till it cools down . ive seen where people have had same problem and changed pcm but nothing says that will fix it for sure . any ideas Im sick of throwing parts at it . and now it has P0340 code no cam referance to pcm
    some suggestions:
    Possible reasons:
    A wire or connector in the circuit could be grounded/shorted or broken.
    The camshaft position sensor may have failed
    The PCM may have failed
    There's an open circuit
    Things you could possibly do:
    Visually inspect all the wiring and connectors in the circuit
    Check for continuity in the circuit wiring
    Check the operation (voltage) of the camshaft position sensor
    Replace the camshaft position sensor as required
    Check the crankshaft position circuit as well
    Replace circuit wiring and/or connectors as required
    Diagnose/replace the PCM as required
