-September 2024 Special Lease Deals-
TRANSMISSION GOES IN AND OUT
I HAVE A 2000 DURANGO THAT WILL TAKE OFF OK THROUGH 1ST & 2ND THEN WILL NOT SHIFT INTO DRIVE OR OD SHE JUST REVS UP THE RPMS IF I LET IT COAST TO ABOUT 35 TO 40 MILES IT WILL SHIFT AND DRIVE FINE BUT IF I HAVE TO SLOW DOWN BELOW 45 TO 50 MPH IT GOES BACK TO LIKE NEUTRAL AND STARTS TO REV UP AGAIN IF I PULL OVER AND STOP FOR A FEW MINUTES IT WILL GO AGAIN OR IF I GET A PUSH WHILE MOVING IT GOES BACK IN GEAR
SO COULD THIS BE A SHIFT SENSOR. TORQUE CONVERTER OR SOMETHING ELSE
JOSEPH
JOSEPH
If that doesn't work, then the problem is probably internal and would require some further testing by a transmission shop. If you do the fluid change be sure to examine the oil pan for excessive amounts of clutch material or metallic debris.
