My right Side Turn signal and fog lamp are out on 2006 Jeep Conmander. Changed bulbs. Still out
BigJoeNJBigJoeNJ Member Posts: 1
edited February 2019 in Jeep
I have a 2006 Jeep Commander. The right side Turn Signal ang fog lamp are out. Changed bulbs. Still don't work
Answers
  • Since you changed bulbs, now it's time to figure out where the power is cut off to the right side. A quick google turns up a 2006 Jeep Commander Exterior Lights Wiring Diagram Note: the page I found this on was for the Commander, but it linked to a diagram labeled Wrangler. I'm assuming they are the same.
    Looks pretty straightforward. Doesn't go through a controller, just the multi-function switch. So you either have a broken/shorted wire somewhere (just have to physically trace the wires and check for continuity) or there's a problem in the switch, or perhaps at the socket. Those can get exposed to a lot of moisture and corrode.
