I have a 09 lacrosse won’t start something is draining the battery have a charger on it when key is
Paul805Paul805 Member Posts: 1
edited May 2019 in Buick
No door chime no dashboard no anti theft radio working with no key and door open I did ohm all fuses all checked good can someone please help
Answers
    Some kind of parasitic drain is possible, but have you had the battery itself checked? If the battery won't hold a charge, that might be a part of the problem. Also, your alternator might not be putting out enough juice to charge the battery.
    Does the car start if you get a jump?
  • Kdot_38Kdot_38 Member Posts: 1
    I have a 2013 Buick lacrosse and I have the same problem. The more I research they more ppl I have found withering GM/Buicks that have the same problem. No one gas an answer and the manufacturer has no answers either.
