IS 250/350 2007 vs IS 250/350 2006
It is almost the beggining of August, I know there has to be some buzz about the 2007 is250/350 comming out. I was woundering if there is going to be a difference, and if the 2007 will bring the prices of the 06 down. When are they comming out, and is it worth the wait?
I drive a 2006 IS 350 and I have to manually turn off VDIM which only takes 10 seconds, but is still a hassle nonetheless. With the 2007 there will be a switch for this. There is a huge difference with this on/off. The car can be driven much more aggressively and after looking at various drag strip times with VDIM on and OFF the car is significantly faster in quarter mile times..........
That dealer is off the mark. Probably just trying to get the 06 inventory moved.
I heard that it will get a sharkfin antenna (nav antenna like others have i assume)
HID as a standalone option.
upgraded wood as an option
vehicle stability control in the is250.
got this straight from the dealer who was getting it from his tech bulletin. sounds like minor changes, not surprising since the car was all new for 20006
IS 250/ IS 350
The popular IS sport sedans also add a shark fin-style antenna and VDIM/VSC cut-off function as well as foglamp indicator, illuminated fuel opener and illuminated trunk opener to their list of standard features for 2007. In addition, the High-Intensity Discharge (HID) headlamps with the Adaptive Front lighting System (AFS) will now be available as a standalone option. New for 2007 is the X Package option for the IS 350, IS 250 rear-wheel drive and IS 250 manual models. This package includes a sport-tuned suspension, alloy sport pedals, illuminated scuff plates, front lip spoiler and 18-inch five-spoke wheels.
Pricing for the 2007 IS line-up (with the exception of the IS 250 AWD which remains unchanged at $34,285) reflects an increase of $265, or less than one percent. MSRPs for the IS 250 manual and IS 250 rear-wheel drive are $30,255 and $31,425 respectively. Base pricing for the IS 350 is $35,705.
It lists everything but the new color Obsidian Black which is on Lexus.com
Netwon
2. i notice that you cant get the nav w/o the HID lamps, is that correct?
odd, isnt it?
