-September 2024 Special Lease Deals-
Honda Pilot Roof Racks
Carry plywood or kayaks on your roof? Or are you shopping for a rocket box. Here's the place to compare notes.
I'm going to contact the Honda dealer, but I'm looking for any Honda Pilot owners with similar issues.
Low cost rack for Honda Pilot 2006
Other than that, the installation was easy. The dealer wanted way too much to do this and I was able to get the rails off the web for $125.
Odie
Odie's Carspace
and after pictures;
I just had to use my leaf blower to dry the car before hand. And yes I use my leaf blower after I hand wash to dry it faster so I don't use a crap load of towels drying.
Odie
Odie's Carspace
Roof Accessories
Just click on what ever you need, plus they have install instructions in PDF format.
Hope this helps.
Odie
Odie's Carspace
Hope this helps.
Odie
Odie's Carspace
What's the difference, and can I really not use the EX-related crossbars?
abryce41@comcast.net
pringles, "Honda Odyssey Accessories & Modifications" #540, 18 Aug 2005 6:28 pm
The van referenced is a year or two older than yours but maybe it'll help. Have no idea if the Pilot crossbars are the same as the ones on the Odyssey.
2007 cross bar only - installation - EX, EXL, Touring
http://www.bernardiparts.com/Images/Install/2007_Odyssey_RoofRackCrossBars_AII33- - - - 183.pdf
2007 cross bar + roof rack installation - LX
For other years - goto above site and you can find them in Honda accessories > rack
1. The picture looks like they are removing the front. This is incorrect. You only need to remove the back covers.
2. Even with the retaining clip depressed, you still need to give it a good hard whack straight back (away from the van). I used a wooden paint stick and put it inside the rail groove. Tapping it with a screwdriver is not hard enough, you need to thump it pretty hard. I actually used a small rubber mallet. It did not damage the retaining clip.
3. Do not try to pry the cover up. It will crack.
4. Do not climb on top of the van. If it is like mine, it will dent pretty easily.
Good Luck
http://www.carspace.com/bigdadi118/Albums/bigdadi118%27s%20Album/Yakima_GetoutCa- rgoBag.jpg/page/photo.html#pic
Just bought a 2010 Pilot EX-L. I am concerned about some of the earlier posts about the roof rack w/ cross bars causing stress dents on the Pilot panels. Any more info on this. Is this a safe design? Any loading limitations.
Diesel
Does anyone have more information? Will Honda repair this? The load in our cargo box was rather light, but the wind force must be fairly dramatic at highway speeds.
