are 2005 odessy (touring) ajustable
odessytalkodessytalk Member Posts: 1
edited June 2019 in Honda
my honda has mild lifter noise a friend suggested using 10w30 oil any advise
Answers
  • Check your oil level. Also possible your oil pressure might be low.
  • thecardoc3thecardoc3 Member Posts: 5,877
    The valves are adjustable.
    Intakes should be .008-.009.
    Exhausts should be .011-.013
    A little noise from mechanical valve adjustment is normal, if they aren't making any noise at all they are too tight.
