Instrument Panel Lights "Check Engine Light" no longer works 2006 Chrysler Sebring convertible LTD
mrbarnardmrbarnard Member Posts: 2
edited September 2019 in Chrysler
My Chrysler Sebring convertible Limited 2.7 V6 gas has 81,000 miles. I discovered during a smog test (which could not be completed) that my CHECK ENGINE LIGHT no longer works. It does not light up when the ignition is turned on and all the lights display. It is the only light that does not work.
Does anyone know how to fix this problem?
  • mrbarnardmrbarnard Member Posts: 2
    It was burned-out idiot light bulbs. Very difficult to buy somewhere, but I found a 2006 Sebring in a "you pull" junkyard and grabbed all the bulbs. Pulling out the instrument panel on my car and replacing all the idiot light bulbs was fairly easy.
