2010 Nissan Pathfinder starting issues
We have a 2010 Nissan Pathfinder, which we bought in 2016 and have had this issue since day 1. When the temperatures begin to drop to 40 or below, our pathfinder will not start. It turns over but won’t start. But, when being jumped, it will instantly start right up.
We have replaced the fuel pump, alternator, starter, relay sensor, ignition switch, the main computer thing (sorry, not a car person and don’t know the correct terminology), the battery connection cables, and the battery 3 times. No mechanic can figure it out, the Nissan dealership is clueless. When scanned, it doesn’t throw any codes but will throw a blank screen which has everyone puzzled.
I can’t, in good conscience, sell it to anyone knowing it’s totally unreliable. I have read multiple forums and I know I’m not alone with this issue.
Has ANYONE found the culprit to this annoying issue and had a successful fix to it?
Answers
A semi-extreme illustration... save you DO have a compression leak. If you turn the engine over very slowly, the air/fuel mixture would simply be forced out the leak without compressing enough for combustion to take place, right? But if you turn it over faster, the mixture wouldn't have time to "get out of it's own way", compression might then be high enough for the engine to fire.
If it IS compression, and is just on that edge of being enough that the cold temps exacerbates the issue, that MIGHT explain it.
Have you noticed any mileage or power drop offs?
The whole blank scanner thing still makes me think there's an electrical or ECM issue as well
Let's see if we can loop in some of our wiser members here.. @thecardoc3 @imidazol97 any thoughts?
Sorry, I’m a female so bare with me. I’m pretty clueless about vehicles.
Need to eliminate possibilities and narrow things down. A compression test would let you know if there are any issues there. That might be where I'd start
