Power mirror issue, 2006 Honda CR-V
behr121002behr121002 Member Posts: 1
edited November 2019 in Honda
Hello all.
Problem: No power mirror movement, either side. Fuse good. Armrest switch seems fine.... no apparent breaks or burned spots on switch circuit board. Can't believe I have 2 bad mirror motors.
Possible alternative issues? Where to check out on car?
Answers
  • rickdonrickdon Member Posts: 123
    Maybe the switch that toggles control to the right and left mirror motor went bad.
  • Being that both sides are out, the problem seems like it has to be the fuse or the wiring to and from that fuse that supplies power to the switch. I suppose it's also possible that the switch circuit board itself has gone south, since as you point out, two mirror motors going bad at the same time would seem unlikely
