no power to electrical box
georgieboygeorgieboy Member Posts: 2
edited November 2019 in Chrysler
Hi folks im new to this group,i have a 2005 pt cruiser .
Passenger side head light wont work there is no power coming # 19 under the dash.
Where do i check its hard to see anything,such a small engine compartment. the bulb is good the fuse is good this is for the low beam both highbeams work great.
Please help.
  • thecardoc3thecardoc3 Member Posts: 5,871
    Power to the right headlight (fuse #19) comes from the same feed circuit from the headlight switch that feeds the left hand leadlight (fuse #20). So if you have power at #20 and not #19 then the fuse block has an internal failure.
  • georgieboygeorgieboy Member Posts: 2
    How do i repair this?
    First thought would be to potentially replace the fuse block. If you are sufficiently skilled, you "could" install an external fuse around the fuse block to restore power to fuse #19's circuit. You could disassemble and repair it. It may be possible to move that fuse and power to a different socket. It really comes down to time, skill, and cost.
