2008 Silverado clunk felt after brakng. Feels like somthing in supsension is unloading preasure.
Used truck I have had for about 6 months. Had the unloading clunk when I got it. 125K miles.
I replaced both front struts and upper control arms.
Strut boots were torn and struts appeared to be oozing a bit.
Upper ball-joints on control arms were both bad. One had been previously replaced but felt tight and gritty. Other had no resistance to movement.
Brakes appear good and all bolts are tight. I will probably do lower control arms and tie-rods as well as sway-bar links next as well as rear shocks. and get it aligned.
Anyone else had the unloading clunk/shift after braking and if so how was it fixed?
Seem like I am heading down the right path?
Thanks for any input.
Dave
Dave
Answers
I'll check rear brakes regardless to ensure all is tight.
Thanks for the reply.
Pads look good but at 50% wear in the front harm in replacing the pads and checking all the hardware.
