-June 2024 Special Lease Deals-
Help - Crown Vic transmission problems
Chris671Chris671 Member Posts: 2
edited December 2019 in Ford
11:44PM
Can someone help me? I just bought a 2001 crown vic form a friend. I drove it home parked for about 30 min and then went to KFC placed my order and let the brakes go and stepped on the gas and nothing. wouldn't move forward or reverse but will go into park. Put it into neutral and pushed it to a parking spot and tried running the gears. Rnd212dnrp nothing checked the fluid can't tell if low or not. Turned the car off and let it sit for about 30 min and started it back up. Went into gear and moved right away but when the engine heated up just off of cold it did it again something wouldn't move. Please help!!!
    RicardowelchRicardowelch Member Posts: 15
    Chris671 said:
    11:44PM
    Can someone help me? I just bought a 2001 crown vic form a friend. I drove it home parked for about 30 min and then went to KFC placed my order and let the brakes go and stepped on the gas and nothing. wouldn't move forward or reverse but will go into park. Put it into neutral and pushed it to a parking spot and tried running the gears. Rnd212dnrp nothing checked the fluid can't tell if low or not. Visit Autofthings to review battery tender for car if you want to get one. Turned the car off and let it sit for about 30 min and started it back up. Went into gear and moved right away but when the engine heated up just off of cold it did it again something wouldn't move. Please help!!!
    It might be an electrical issue or a sensor problem. I think you should check it.
