Chevrolet Avalanche Engine Problems
The new place to discuss your Av engine woes!
Good luck, and I hope it's as simple as needing the filter changed.
a relay? 2003 AV.
The tap I have, sparky75, is related to the hydraulic lifters however not as the dealer explained to you. My tap is NOT at every cold engine start. It is only on cold starts after one of the valves for 1, 4, 6 or 7 cylinders (they are the 4 cylinders that shut down in the V4 mode) while one the high-point of the cam. Then, during the cool down period, the hydraulic pressure bleeds off. Then, when started cold, there is valve lash for over 1 minute (sometimes for 2 minutes) until the hydraulic pressure is sufficient to build up the lifter. The resulting tap is the rocker arm slamming on the valve top as a single, metal-to-metal tapping sound.
I still have no resolution with my dealer, but hadn't thought of the BBB as an avenue. Might try that one.
Alan
Hope it helps,
Rick
Anybody else with same problem?
farthur
today when the engine light on the dash came on. its got about 57,000 on it. and i cked the antifreeze level was low? umm. i leveled it off. also noticed the volt meter in the dash was showin alittle high 14.8 ? might be allright i guess. also the gas cap was loose so i retightened it. my wife drives it........everything seems allright.
all the fluid levels, battery connections. no weird engine noises.
any ideas????????? :confuse:
I have always driven a GM product...I own 5 other Chevy trucks with 5.7 litre motors but have never had these types of engine problems. I love the gas mileage...my AV is a 4x4 and has never left the highway...and I get 21.5 on the highway and 18-19 in the town driving...If the engine proves reliable I would like to own another Av as my dealer states that GM will discontinue it in 2013.
We're glad to hear that your dealership is taking such great care of you! Keep us updated on how everything is looking when you pick your Avalanche up on Monday.
Sarah, GM Customer Service
the dealer will pay half wich is close to 1,100.
and try to get a recall on this issue. and for those who had
paid get their money back. my Avalanche has only 57,700 miles. I bought it new.
the dealer will pay half wich is close to 1,100. the noise is getting worse.
I think that I will fix it and sell it.
Let us know if there's anything we can check into for you. We can be reached via email at socialmedia@gm.com (include your name and contact information, the last 8 digits of your VIN and mileage, and a summary of the situation so far).
First post here...glad to see I am not the only one who has problems with the Av engine... I got mine in today for an engine noise.... 2009 Z71 with 41200 km.... Dealer just called me... he needs to open it up to see what's going on... Asks me to get all my invoices for oil changes as GM will ask him cause it's under warranty. Who keeps oil changes invoices ???? My OnStar is activated and tracks when the oil changes were done...
I am hoping they will cover it even I do not have all the oil changes invoices.... and on top of that, it's always been with Synthetic... I have ALWAYS bought GM my 5th car/truck... not sure anymore...
Good luck !
