Chevy Colorado and GMC Canyon Accessories and Mods
Factory didn't give you exactly what you wanted? Discuss add-ons here!
I had a Rhino liner sprayed in about two weeks afer I got the truck. So far it's great. Nothing sliding around in the back (even empty gas cans will stick on that stuff around corners). Also put a trailer hitch on myself. I ordered one from Etrailer.com with the wiring harness which made the electrical stuff easy. Also had Ziebart throw some molded mudflaps on to keep my paint from getting chipped.
I'd like to put an aux tranny cooler on it for when I tow my boat so I don't kill the tranny. I like the Hayden's OEM style with the stacked plates. I have one on my XJ and it works well and was an easy install. I just need to find out which is the return line to the tranny. Anyone know??
Since I primarily drive this truck in the winter, I installed a set of Bridgestone Blizzak snow tires on it within a week of getting the truck. Big improvement in ride and handling, even though the Bridgestones are "snow tires".
I do drive the truck in the summer at times, and Blizaks don't last too long in the summer, so I made a "performance upgrade" for summer use. I installed a set of 16"x8" wheels, and 245/75/16 Firestone Destination LE tires. They're the same OD as the 265/75/15s, and they worked out quite well. I don't understand why the factory didn't go this route...
I want to install a trans temp gauge and I was hoping someone could let me know who sells a A-pillar mount?
Checked with Summit already.
I have a 2008 Colorado Reg Cab, 4cyl and can't find a cold air intake for it....they only have intakes for 5 cyl. What model and style is yours???
Thanks, Ed
