Alternate fuses for interior lights.
I have an '02 Grand Prix GT. I went to replace the trunk interior lamp as the bracket on the assembly broke (the bulb did light) and it was dangling from the wires. I removed the old assembly (no, I did not cut through both wires at the same time) and replaced it with an LED lamp. The result is that now none of the interior lamps work. I checked the interior fuse block and the fuse is still good. Does anyone know if there is a fusible link or relay elsewhere for the interior light system? Are there any other switches that need to be checked? I fear the problem might be in the PCM circuit that turns the lights off after they are left on for 10-15 minutes.
Thanks for your anticipated help,
Jay
Jay
Answers
