1998 Honda Passport Radiator?
EBarkleyEBarkley Member Posts: 1
edited July 2020 in Honda
I have a 1998 Honda Passport EX, that has been idling in the 2-2.5k rpm for awhile. I changed the temp sensors first and it helped temporarily.
3 days ago, I was sitting in park, vehicle on, and then white smoke rolls out from under the hood. I get out and there’s green fluid on the ground everywhere.
The tow truck driver said it was the radiator, so we checked and there’s a hole busted in the plastic manifold above the radiator.
Should I even replace the radiator? Is it worth it? Will it lead to the head gasket, water tank, or temp gauges?
Answers
  • What choice do you have? Changing a radiator shouldn't effect those other components.
