Volvo V50 Audio & Entertainment Questions
From AM/FM to ipods and MP3's, this is the place for your questions about your V50's entertainment systems.
I've installed FM Modulators in Toyotas and a Miata and I love the results.
Any information would be great!
I recently leased a 2005 S40, which has the exact same interior/dash/audio as the V50. Here is my post from SiriusBackstage.com:
Hey all - well - I finally took some pictures of my Starbase install in my 2005 Volvo S40.
If any of you have read any of my recent posts RE: installing Sirius in the 2005 Volvo S40, you are aware that all 2005 Volvo S40, V50, and XC90 have no way (currently) to hardwire (either Aux or SATSWB) a satellite radio to the audio system. The guy from Volvo tech support explained to me that there is actually no antenna wire in the car but rather, a new fiber optic cable system known as MOST. My only choice was to try the wireless FM transmitter.
Well, it works amazingly!!! Now it is important to note that the sound quality is ONLY good if you plug in one of those FM antenna wires they give with the Sportster - into the FM out on the Starbase tuner. Without this wire, the sound quality is terrible. But with it - it is almost as good as hardwired!!! I was amazed myself!!
If anyone has any questions at all about the install - please let me know. Also, the antenna is on the rear deck - inside the car (up against the back windshield) - perfect reception - no dropouts whatsoever - and I live in Long Island, NY so that is a good test of the reception and sound qaulity.
Man do I love my SIRI!!!!
Well, anyway, here is a link to the finished product
http://pg.photos.yahoo.com/ph/funhouse_ny/album?.dir=/ef15&.src=ph&.tok=ph444uCBX4yOMjdm I is basically the same
So my questions are--Does the factory stereo (or the upgraded audio package) have an AUX input and an adapter available? Do any of them charge the iPod as well? Does anyone know of a source of information on the V50, factory stereos, and ipod adapters?
Len
Apple/Volvo press release
I was told by Volvo corporate (when the Apple press release was issued a couple of months ago) that the v40/50's owners could buy an FM transmitter that was sold through Volvo (avail summer/fall 2005).
I already have a (non-Volvo) transmitter and I rarely if ever use it in my Volvo due to FM static which is very apparent when playing the iPod. I have the 12 speaker premium sound system, so I don't know if that has something to do with the static or not. The same transmitter however works perfectly fine with my 2002 New Beetle's Monsoon system and in my 2004 F-150, so I don't know what's up with that.
When the Volvo transmitter comes out I plan on getting one, but will return it if there is static (the other issue is that these transmitters are supposed to "hang" off the dashboard to the right of the radio with your iPod swinging away). Because Volvo does have aux jacks in the other models, it may mean that the radio system in the v50 (under the current design) is not capable of dual input systems (CD / MP3) due to the motherboards themselves.
I use the iTrip FM transmitter, and play my iPod back through a chosen frequency on the FM radio. With high resolution, you get CD quality music. It's simple and cheap ($40). Since the antenna is in the rear hatch glass, reception is good from anywhere in the car!
Cheers,
Rousslang
It can be done, it's inexpensive and it's worth it.
Cheers.
Could you please share how you installed the cables and what is needed? I want to get this to work too!
thanks !
We have a 2005 V50 and have found that 1/2 of the time when you turn on the radio no sounds comes out (either radio or CD)
Thanks. V
I just took delivery of an 2008 S40 T5 FWD. It is a wonderful vehicle that has numerous incremental improvements over my 2007 V50, some of which were expected and others of which were pleasant surprises.
The only disappointment thus far is the new Dynaudio digital sound system, which is simply not only not as good as the Dynaudio in the C70, but also not as good as the Premium analog system in my 2007 V50. The high end response may be marginally cleaner than the latter, thanks to the Class D digital amplification (Dynaudio licenses the ICE power technology from a division of Bang & Olufsen), but the low end response is very weak compared to the 2007 V50 Premium system, even with the latter's subwoofer disabled.
I don't think that adding the dealer-installed subwoofer option to the 2008 S40 Dynaudio will help it appreciably, since it is largely ineffectual in the V50. The only upside to this problem is that the new Dynaudio system didn't cost any more than the old Premium system.
My best guess is that the Dynaudio system was designed with the supplementary integrated subwoofers of the C70 in mind and doesn't work well without them without further design tweaking. Unfortunately, the dealer-installed trunk subwoofer simply doesn't deliver the same performance as the C70 integrated in-cabin ones. My V50's Premium system doesn't sound appreciably different with or without the subwoofer.
In theory, it might be possible to improve the frequency response of the Dynaudio digital system with a firmware upgrade, but whether the unit is actually capable of accepting software upgrades is unknown to me. It is certainly something I will be looking into.
I am currently experimenting with tweaking the frequency response through the equalizer settings, but as any experienced audiophile knows, this is not wholly effective if the low frequency drivers' response is not very good to begin with. In any event, it is a minor complaint with an otherwise superb vehicle.
I have a 2.5" HD of 320Gb. How should I format it to be able to use the full disk size for music by connecting it to the USB plug in my Volvo V50? When I format it with 1 partition, 320Gb, fat32, the car audio system does not recognize it. When I format it with several 32Gb partitions, it only recognizes the first one, not the other partitions. (so I lose 288Gb)
What should I do? :confuse:
I can alter the volume from the steering wheel. But is there a way I can skip a song or go back to the beginning of a song using the steering wheel?
Thanks very much for your help and Happy New Year.
