Volvo V70 Brake Problems
in Volvo
Discuss V70 brake problems and share your solutions here.
We have had the car for about a week and the CD player has ceased to function. We took it in for an oil change and it also needs a $600 brake job (new rotors all round). I am a bit concerned about these unexpected flaws, and about the information I am reading about the v70's brakes on various spots on the Internet.
Could someone with some experience answer a couple of questions for me?
1. Is the CD player covered under manufacturers 5 year 50k warranty? I am thinking 'no way!' but had to ask.
2. The repair shop with whom we have been doing business for many years works on volvos a lot. They told us that due to the design/materials of the volvos brakes it is possible that we would have to replace rotors each time the brakes start to go! Is this true?
Other than these things, the car seems rock solid, and very comfortable. I think you'll agree that these problems and expenses, within a week of purchase, are reason for anyone to be concerned.
If you could answer those questions, and provide any general impressions on maintenance costs for the '02 v70 wagons, it would be most appreciated!
Thanks, and happy motoring to all!
ddb
I take it that you didn't buy the car from a Volvo dealer?
The brake design on Volvo's is optimized for short stopping distances and rapid heat dissapation.
Heat is the enemy of a braking system.
The pads are very soft in order to facilitate heat disapation. The rotors are thinner that other car makes in order to do the same thing.
Over time, heat buildup warps brake rotors, and if you don't change the pads at the right time, you can score and damage the rotors.
On a run of the mill car the rotors can be turned, that is they can be machined flat again.
Volvo rotors cannot be turned.
The rotors DO NOT need to be replaced every time you do pads. Only if you score them or overheat them. Yes, eventually they will need to be replaced under normal maintenance, but not every time.
ATE replacement front rotors cost $52 each. Mintex pads are $35 a set.
My 2004 V70 has 40K miles on it now and the pads/rotors are fine - I'll probably get another year out of them.
Why is $140 every 3 years enough to make you change my driving style?
My local dealership wanted $800 to do the 45,000 mile scheduled maintenance - and that didn't include the brakes. Needless to say, I wasn't going to pay that!
I bought 6 quarts of Mobil 1 10W-40 synthetic for $36.00, an oil filter from the dealer for $6.00, and Mintex "red box" front pads from eEuroparts.com for $37.00.
Last weekend, I spent about 2 hours in my driveway inspecting belts and hoses, changing the oil and filter, and replacing the front pads. The rotors were in fine shape but the pads were down to about 3mm of material remaining (we used them up!). I was pleased to see that the calipers are basic Ate units - really easy to work with.
Oh yeah, the OE Michelin tires are down to 5/32 tread depth. I'll replace them with a set of ultra high-performance all-seasons before the end of the year. I have a set of Pirelli PZero Nero's on my BMW and they are terrific, but I'm thinking about trying the Kumho Ecsta ASX on the Volvo (the Kumho's are very highly rated and almost half the price of the Pirelli's).
What I find confusing is that there is no warning sensors to indicate worn pads...Can this be true? I dont th8ink we drive the wagon hard and live in a warm coastal environment. Pads I can figure but rotors at 37,000? Dealer said it's normal and that they suggest rotors and pads around 25 - 30,000 miles..Hughhh?
Any one out there have a take? thanks! jscinca@aol.com
Go to ebay and search under v70 to find the abs repair guy (BBA re manufacturing) and opt to send yours in for repair ~$66 or get a replacement for ~$100. Otherwise expect to pay upwards of $500 - $700+ if you take to repair shop.
FYI: car is still drivable if you only remove the control module & not the pump. It's a easy DIY job and takes only ~1-2 hour to do. The ebay site shows you how to remove/install.
Hope this helps.
It started as a whining sound but progressed to a rushing sound.
I saw your message concerning ABS warning light on in your Volvo.
I too have similar problem with my Volvo XC 70. The ABS lights are on and also at times together with the engine light.
Have mechanic checked and cleaned the ABS sensors still not fixed. Have also reset the computer - still not fixed.
I just wonder whether your ABS problem has been rectifed?
Can you please advise.
Ah Kow Yee
Boonah, Queensland,
4310 Australia.
It may be possible to reseat the seal after pulling back the bellows at the rear of the booster. For many Volvo boosters the rear seal is the only available service part and failure to rectify the problem will result in the main diaphram rupturing requiring the replacement of the booster this is typical of V70 Australian models, and very difficult and expensive to replace. On american models which are fitted with a vacuum pump this will lead to pump failure if not rectified as the pump will run continuously and burn out the pump.
