Hyundai Sonata Airbag Issues
Ok so I have an aftermarket remote starter. Whenever I use this unit to start the car, my Sonata will give the "Passenger Airbag Off" regardless if I have a passenger next to me or not. I have told Hyundai about this and they tell me that the computer has determined that the person sitting there is in a position where the airbag deploying would not be beneficial in an accident. This may be the case in some situations, but I find this extremely hard to believe that EVERY TIME I use my remote starter, my passenger is in an unsafe position. I have had passengers jump up and down, wiggle around, moved the seat forward/back, incline/decline etc....still no go.
If I turn the car off and restart the car with the key, while the passenger is in the car the "passenger airbag off" indicator is unlit specifying that the airbag WILL now deploy.
Does anyone have any suggestions? Realistically I could use the remote starter to warm the car up...get into the car and turn the car off and restart with the key every time but that seems like a pain in the [non-permissible content removed].
I'm wondering if there is some type of time limit for a passenger to sit on the seat to activate the airbag....kind of similar to the seat belt chime which will go off after 10 minutes.
Thanks for the help/ideas/suggestions in advance.
In terms of the aftermarket company, I'm not sure how it could possibly be their job to make sure that the car's ECU does its job properly. The job of the unit is to start/stop the car...maintain proper tach....keep a timer of how long car has been running and if over alloted time period stop.
Thanks for your thoughts/ideas/suggestions. They are very much appreciated.
OTOH, the manufacturer of the remote starter wants you and every other Hyundai owner
Are there other aftermarket remote starters made by different manufacturers? If so, it would be interesting to know if they also do this.
(BTW, you don't really want us to leave you alone, do you? :P )
This should make 06 Sonata owners happy...Just bought one...Now it has to go in to get all this crap fixed...Surely, it is definately Hyundai's fault...Otherwise, love this car...
Airbags not deploying....
