Lincoln TC 1990 trans rumble
My 1990 TC has a rumble when changing gear from 2nd to 3rd (17mph to 27mph) no problem if you put your foot down on the gas hard. It's done 240K, I've had it a year and not changed the plugs or leads - or the trans fluid; could this be the cause? It has very little use, only started after I'd driven it for 10 miles(it was fine) then I stopped and thats when the problem started.
P,.S. Be sure to drain the torque converter (fluid coupling)
