Mazda B-Series Electrical/Lighting/Computer
The place to discuss things in your Mazda B that should go ZAP but don't
kcram - Pickups Host
kcram - Pickups/Wagons Host
Turned on the lights the windshield wipers/wash came on...
pushing the windshield wash button, instuments lights came on..
next day tried the lights and horn now blows :surprise: !
>OBD code is zero
>Disconnected then reconnected negative battery terminal
(still get the horn when I turn on the lights...)
I'm trying to figure out how to get into the steering column?
Is the above TSB about this problem? couldn't locate full text and
and diagrams.
Thanks for any ideas, russell17
Also, could it be a bad light relay and where is it located? or can the light switch be serviced once it is removed, does it come apart or is in one unit with all the functions sealed in a uni type switch?
Any help would be appreciated. Oh yea, does the horn and stearing wheel bolt cover need a special tool to remove so you can remove the stearing wheel to get at the light switch behind it?
Thanks for amy help.
Rockhound Rider :confuse:
My question is: where is the switch and how do I fix it?
kcram - Pickups/Wagons/Vans+Minivans Host
I'm thinking it's electrical, and was going to work from the ignition out, but can't figure out how to get the steering column cover off.
Any suggestions or help?? Thanks!!
