front brake wont release
2006 GMC SERRIA 1500 SLE 4 DOOR FRONT DISK REAR DRUM BRAKES. PASSENGER SIDE FRONT BRAKES LOCKING UP . AFTER APPLIYING BRAKES.
REPLACED ABS CONTROL MODULE ( DID NOT FIX) NEW ROTOR, CALIPER , BRAKE PADS. INSPECTED FLEXABLE BRAKE LINE NO PROBLEM MASTER CYLENDER SEEMS OK ????
Answers
Best thing to do is when it locks up, Crack open the bleeder, if it stays locked, caliper is bad, if it frees up, brake hose. Since you replaced caliper already, odds are its ok and its the hose. I have had the caliper brackets be all crapped up inside causing the slide pins to not float.i always either replace the brackets as well when doing a brake job or clean the holes really well and lube them. I trust you cleaned and lubed the slides correctly.
