How many thermostat gaskets or O rings are required for a 2012 MKZ with a 3.5 liter engine?
[Deleted User][Deleted User] Posts: 0
edited August 2021 in Lincoln
Want to replace a thermostat on a 2012 MKZ with a 3.5 liter engine. Some sites show 2 gaskets required. Is that correct?
Have replaced many thermostats in Ford, GM, and Chrysler vehicles and have never seen one requiring more than 1 gasket.
If 2 are required where exactly do they go?
Don't want to drain coolant and open up the thermostat housing and be short a gasket.
  • thecardoc3thecardoc3 Member Posts: 5,878
    Two part numbers come up when I search. F1VY-8255-A is the only one I see for the 3.5l and it is an o-ring that seals the housing and the thermostat at the same time. The 3M4Z-8255-A seals the housing on the 2.5l when a seal on the thermostat itself isn't used.
