Chevrolet Blazer/GMC Jimmy: fuel tank problems?
Hi when I try to fill my car up with gas the pump will shut off almost instantly and will not stay on (this isn't the gas stations fault). What could cause this? Would it be and air hose for the tank that is clogged so the air can't get out or what?
I usually happens about 30 seconds to a minute after I shut the Blazer off.
I have also noticed that the gas pump will sometimes shut down when getting gas.
Is this the same problem as above? Or, is the "thump" something else? It sounds like the gas tank is either releasing pressure or could something like a vent be clogged?
I never thought it could be the muffler. That's a relief.
Anyhooooo...my buddy and I deduced that this must be a hose that captures spillage and routes it back to the tank, for those times that the truck is driving on bumpy roads, rocky terrain, etc. What I need to know is 1) WHAT is this thing called, and 2) is it necessary to replace it, or is there a way to patch it up or bypass it without any problems? It's not mentioned anywhere in the Haynes manual -- so I think it's something GM got rid of after my model year, and the Haynes people were unaware of.
This is especially frustrating because we've done most of the work and just need to put the tank back on. Thanks for the help!
Raphael
