Sport Trac Remote start
I am installing a DesignTech remote starter w/door locks and alarm bypass. Everything is connected except the door locks and horn. Does anyone know what colors these wires are and where they are located? Thank you!
Mark.
I know that Code Alarm products require a separate module to work and that some other systems require you to get a programed ignition key from your dealer that will then be permanently installed in the alarm box.
Mark.
You probably should have bought a Code Alarm system, or the Ford version of it, as there is a lot more info on the web about these if you have trouble getting it to work. If you ultimately can't get the DesignTech to work, this would be something to consider.
