2015 Lexus NX200t - No Start
DominusVIIDominusVII Member Posts: 1
edited August 2022 in Lexus
Greetings all -
Any feedback would be appreciated... We are in the process of trading our Lexus in for another. We recently prepped the vehicle, and kept it in the garage; while we turned it over a few times and took it out to keep the battery charged, it has been sitting for the past two weeks and will no longer turn over. We initially heard the typical starter noise associated with a struggling battery and as a result, I proceeded with a trickle charge for two days to recharge it. When I came back to turn it over, the vehicle was stone cold with no response, no interior/accessory lights, etc. I then attempted to jump start the vehicle with the same charger and there was absolutely no response.
This was a first for me in terms of a vehicle not showing any response whatsoever to neither a trickle charge nor a 70A Jump. Am I missing something?
Any thoughts, insight or recommendations? Thanks in advance... :)
Answers
  • thecardoc3thecardoc3 Member Posts: 5,871
    70 amps for a "jump start" would not be enough power to start the engine with a completely dead battery. You can try measuring voltages at the fuses while jumping the battery to see just how much power is available while you have an assistant attempt to start the engine. I suspect the voltage level will probably be proven to be too low. At the same time, you can check for open fuses just in case something happened and a main fuse has failed.
