-September 2024 Special Lease Deals-
Pontiac Grand Prix Heater blower relay switch
perplexed3
Member Posts: 2
I need to locate the heater blower relay switch.My heater only works on 5 and have been told it is prob the relay switch.Any ideas where it's located and where i can find a manual showing location??? thanks
1. blower fan
2.resistor
3.heating control assy.
now i still have problems with only speed 5 after putting all that in. you would never guess what it is now.
the ignition switch, not key put, the wiring part in the steering colume. that runing me 100.00 tommrow i will be putting that in. so to say i had all the same problem but after doing 1 thur 3 i had found that ignition switch is the problem when only 1-4 dont work and running lights go off. so keep eye on that because this sucks. i have been fixing cars myself for about 5 years. some isnt easy but trying to track the problem. i would have never guess ignition switch, that is what starts the heat in the first place. have a great time... christy
The problem now is when I turn on the blower motor switch the car lights do not work, the car monitor on the console doesn't work, the seat heater doesn't work, and you have to manual turn the headlights on for them to work.
Does anyone have any suggestion's on what might be going on?
Tony
I have a 2000 GP GT with 79k on it.
I have been experiencing all the problems regarding the water leak (for a year or so) and the problems with the blower fan/resister board/daytime running lights.
I shared this information with my mechanic, who was working his thru the problems to this.
He's going to finish today, with the help of this info, and hopefully be able to keep the bill down a little.
My car has had one other "sporadic" issue. The car would occasionally stall, typically during SLOW, RIGHT turns. I'm hoping that may be ignition related as well.
THANK YOU!!!!!
Thanks in advance for the response
I printed off some of the earlier postings on this and showed them to the mechanic. They were amazed at the solution, they never thought the ignition wires would cause fan/running light issues, go figure.
Hope it turns out well for you!
Thank you, Jesse
Thank you; Jesse Cutler
Also, can u give a better idea what things (other parts) had to be removed to replace/instal this piece(s).
Did you use any carbooks (which) to guide you/were u able to test the wiring w. a voltmeter, before u determined it was necc. to replace it?
And how do u change it without a repair manual (seems the shop manual,..150 plus bucks,..is all that's available)?!
Also, what year was the car u were refering to, & where is the resistor (same side as blower?)??
A picture someone gave me shows the blower clearly on the right side of the dash (under the passenger side, just near the middle dash), but, it shows , apparently, the resistor is on the other side (e.g.to the left of the middle of the dash, just to he drivers side of the 'middle dash'.
Christy, is the resistor direclty mounted onto the blower motor of your vehicle (or is it separate?), and do you know if your 1999 GP, & our 2002 GP have the same configuration?
As soo as I can, I'll put my 'blower breakdown chart' on this forum (it should help a LOT of people!).
Also, i order of problems noticed:
1)Pass power window stopped working 2 years ago (worked briefly after gettng new battery), and twice 3 mnths ago, other windows briefly failed).
2)Power locks lock by themselves (when eneigne running, & person unlocks with drivers switch, then leaves car for a moment).
3)Fan started intermittently not working on settings 1 & 2 (3, 4, & 5 ok), but then stopped working on all speeds.
4)daytime running lights presently working intermittently (even when blower switch in off position).
5)Rear defogger ha stopped working.
All this, and NO windshield leaks have been noticed (yet).
try that website, it has pictures and that is how i changed mine also tells what tools to buy.
I hope than it doesn;t turn out to be the ignition wiring(thank you for you providing that link/the step by step pics of how to install the new (ignition) wiring. It looks complicated (a repair manual would help/none for my model year exists yet,... that is x-cept for Pontiacs $130.00 'shop' manual trio), so i hope it doesn't end up being the wires.
I am just about to try what may be a shortcut (around buying, or installing a new blower motor 1st (to see if that solves the problem), by 1st using jumper wires directly from a power source (the battery, if necc.), and connecting them directly to the blower motor. If it doesn't work, then i replace it, only then (i wonder if others thought of this before paying/installing parts,..sounds like no one did. I diddn't think of it immediately, either.). Always remember, u can test almost ANY electical parts on the car/else where, with jumper wires, as long as u know what you'e doing.
If the blower works, then the problem is finding how to test the resistor (maybe then i would just buy 1,.. but plug it in without fully installing it,..so i can return it, if necc.).
Have u dealt with dex-cool gaskets problems (am considering selling the car, before this happens)?
I'm (originally) from San Francisco, Cal., but currently live in Fontana, Cal.
Thanks Christy (and u are from,....?)!
I bring this up, cause i;m going to examine like crazy (at least from the outside or harness end of the wiring, before I replace it/them (I saw a warning about being careful about the air bag system).
Have u had any (other)probs. with your '99 Grand Prix?
And do u know if the '02' model is similar to your (wiring wise)?
As with Chrity, every little bit helps(thanks for the info,...it's GOLD, believe m!).
1 thing, in my case, the instance of the blower not working on 1 &2/ & only working on settings 3, 4, & 5, was just 2-3 weeks. Then, blower failed completely (and intermittent problems w. lights/etc., began.
I completely agree that, if it's easy, just cleaning the contacts in that box you described should be enough ,.....what did u use to clean them, by the way. I thought of using that 'electronics cleaner spray' that's at most auto stores, but, although it says 'leaves no residue, it leaves something that turns white,..so I wonder if that would interfere w. electrical conduction.
I just found & unplugged the electrical connector to the blower, tested, & found that it IS getting around 12 volts on all settings of the blower switch (my meter showed 11.91-11.97 vlts.).
Also, i plugged the plug back into the blower (with the ignition switch o run, still, e.g., power on), was preparing to leave, when (after about 1 minute), what do ya know, the blower starts blowing! It was randomly left on setting #5, & when I switched to another setting, it went off (& stayed off,.....even after i tried setting 5 again).
For many of you that mentioned water leaks harming your blower, i did notice dried water spots, but on the opposite side of the connector (didn't see where the resistor was).
Anybody have any opinions. My best guess is that the blower probably has a short in it, and to go to a junkyard & get a replacement. (this assumes there is no such thing as a load/no load reading factor in the 12 volts i rad, when it comes to heavy load things, like blowers!).
Also, anybody know what that 'cooling hose connected to the blower work (maybe it got clogged at the other end, & blew the blower)?
I guess what I'll do is get a solid power source, & use jumper wires from it, & hook them to the blower directly (while it's still in the car), & see what happens.
That way, if it's as in your situation, i wouldn't have done much work.
2 things; what year is your car, & (just in case), where was the resistor located (on what side, angle, etc. Also, is it attached to the blower ,...i can't find it?
I want to eliminate that too, before I'm faced w. the bad news (of ultimately changing the switch/wiring).
It looks ominisly identical to the '02 model, which surprises me (also that Pontiac hasn't fixed the successive problems.).
How did you deal w. that thick/solid hose full of wiring across the blower (on mine, it's more cramped for space, as you'll note in the pic there's nothing to the right of the blower,...)?
Did you use any specialty tools w. the blower or resistor removals?
How many miles did you have when your blower gave out totally?
