Mode door actuator
[Deleted User][Deleted User] Posts: 0
edited July 2023 in Chevrolet
I have an issue with the HVAC.... air will not stop blowing to the floor no matter what setting I chose. I understand it is the mode door actuator that needs to be replaced but I'm sure a chevy dealership will charge an arm and a leg to replace it. I'm at the point now that I just wanna get in there and manually close the door for the summertime to keep the A/C from blowing to the floor. Anybody have an idea how to get to it??? I don't care about replacing the mode door actuator, just wanna manually close the mode door.
  • thecardoc3thecardoc3 Member Posts: 5,871
    You should get actual estimates for the repair, instead of just fearing the worst. The mode door actuator is a relatively minor repair. In fact, trying to just remove it to make the system manually adjustable would have you at the halfway point of the replacement.
