Hyundai Tiburon (Coupe) 2007 1.6 signals, dashboard light, electric windows not working
Clashduv27Clashduv27 Member Posts: 1
edited October 2023 in Hyundai
Hi. I recently came back from vacation after 3 weeks and restarted my car to find signal lights, dashboard light (main light that usually lights up all dashboard) electric windows and rear window defogger not working.
Any ideas on how to go about fixing this? Could it be that several fuses have blown? Cause from research I know that it’s not the same fuse controlling all those things. Or could it be some short that’s happened that’s blown all those things?
Some help in how to go about fixing these issues would be really appreciated!!
  • thecardoc3thecardoc3 Member Posts: 5,871
    I pulled several schematics to see if anything was common. There is a 50amp "fuse link" in the under-hood fuse block that feeds the body computer which provides power for the rear defogger, power windows relay, turn signals, and hazard flashers as well as a few other systems. The first thing to do is check to see if you have power at any of the fuses that are fed power from that fuse link. One of those would be the 10amp hazard fuse for example and/or the 30amp defogger fuse. If there is no power to them then you need to identify the 50amp fuse that feeds those fuses and check it for power.
