Dash Cam Parking Mode
I consider acquiring a Toyota Prius Plugin Hybrid for my next car. I would install a dash cam which has a Parking Mode that keeps the car under surveillance while parked. While in Parking Mode The dash cam is powered by the car's battery.
To retain enough battery energy to start the car, the dash cam has a cutoff switch that will turn off the camera when the battery voltage declines to 11.8V. But this voltage is meant for lead acid battery. The Toyota Prius Plugin Hybrid has a lithium ion battery. Will this cutoff switch work with that lithium ion battery?
