-July 2024 Special Lease Deals-
homemade small retrieving tool for those things that fall down the intake r
thesandman7thesandman7 Member Posts: 5
edited March 2014 in Chevrolet
i recently had the bad luck of dropping the stainless steel fuel line retainer nut down the intake runner in my 2000 blazer. as anyone knows, magnets do not exactly draw to stainless steel. after racking my brain for 2 days and almost resigning myself to the possibility that i would have to remove the lower intake and possibly the head, i came up with this nifty little trick that i would like to share with you. i don't know if anyone has done this before and if they have, i apologize. for the cost of about $10.00, it works. here goes. you need:
a large baby bottle nipple found in the infanst section of the local Walmart or similar store
an at least 2 foot section of 1/2 inch I.D. soft vinyl tubing from Home Depot or similar hardware store
your wife's vacuum cleaner or your shop vac
cut the tip off the nipple, as much as you think is neccesary then slide the tube thru. leave about 1 inch inside the nipple. using the vacuum cleaner hose attachment, slip the large end of the nipple over the hose attachment. it should be a tight fit. once you have it attached, test it to make sure everything is attached right. slip the tube down the runner and turn on the vacuum. wiggle the tube around until you hear the sound of the nut or part being sucked into the tube. you'll know, believe me. remove the tube and turn off the vac right away. pat yourself on the back many times.
the vinyl tubing comes in different lengths from Home Depot or any hardware store. this worked for me and i hope it comes in handy for some of you out there that find themselves in the same pickle.
    Got any photos? This trick would make a handy Guide!
    That depends on the which stainless steel you're talking about. 400 series stainless works just fine with magnets. You're probably looking at 300 series. The relative amounts of chrome and nickel determine whether the stainless is magnetic.
    jlflemmonsjlflemmons Member Posts: 2,242
    Jim's corollary to Murphy's Law states, "The magnetic properties of an object dropped into an inaccessable space are inversly proportional to the cost, importance, and potential damage caused by leaving said object in that inaccessable space."
    Yeah, I think I read that in a physics text once! ;)
