2008 Mercedes C300 Headlights and License Plate Lights Flickering
i own a 2008 Mercedes Benz C300 (6 Cylinders 3.0L FI DOHC 183 CID) and i'm experiencing issues with my headlights. they randomly turn off and on without any specific pattern. sometimes they stay off for 10 seconds, other times for a minute. also, the lights that light up my license plate flicker too. i suspect these issues might be related, but i'm not entirely sure. any advice would be greatly appreciated.
edit:
after researching common problems with my car, i suspect the issue might be a faulty headlight switch, which looks to be a common problem. i'd appreciate confirmation from other reddit users if this seems likely, or any advice on how to diagnose the issue further. i can provide video and pictures.
edit:
BTW is this with or without the HID headlights, and is it the high beam, low beam or either that are going out? Plus, when the lights do go out does the "flash to pass" still work or is it not functioning either?
thank you for the help. the car is equipped with halogen headlights, not hid. both the low beams and high beams go out at the same time. although the "flash to pass" feature still works, it doesnt function when the low and high beams are out.
~ yakunan
