[2010 Toyota Corolla S] Help me decide on buying this car or not
Hey everyone! I'm from upstate NY and looking to purchase my first car. I need a car to take me to and from work (40mi round trip) and maybe a couple of interstate trips a year or so. I just want it to last me for the next 2-3 years hopefully. I came across this 2010 Toyota Corolla S with 109k miles for $6995 (https://www.facebook.com/share/15grss2mCs/).
I went there and drove it around and it seemed fine. There are tiny scratches here and there, the inside is not entirely clean. There is a tiny crack on the center media console (dash), and the engine plastic cover has a crack too (most of these seem cosmetic). I got a mechanic to get it checked as well, he drove it around and he said the car is fine but there are some fixes that he would recommend me to do (he did ask me to drive it for 300miles or so and see how it is). The car has winter tires on the front and all-seasons on the back (is this normal?). He quoted me for about 2.6k
. The guys selling there said they could look into the brake pads and the sunroof but other things they wouldn't fix before selling it. There is minimal rust underneath. Carfax says the car is clean with no accidents but my mechanic said the car might have been hit in the back because I could see the bumpers slightly molded or misaligned.
After NY tax the car comes to about 7.5k. Would you suggest I get this car? I tried negotiating but he wouldn't budge because it is Toyota and he will always find someone to buy it as is which I get because these sell like hotcakes.
I already paid like $300 downpayment to hold the car and have a Bill of Sale. And I have until Monday to pay the rest. They said they'll do the NYS inspection and get everything checked out by then.
What should I do? Would you recommend me to go ahead with this purchase? Thanks in advance!
. The guys selling there said they could look into the brake pads and the sunroof but other things they wouldn't fix before selling it. There is minimal rust underneath. Carfax says the car is clean with no accidents but my mechanic said the car might have been hit in the back because I could see the bumpers slightly molded or misaligned.After NY tax the car comes to about 7.5k. Would you suggest I get this car? I tried negotiating but he wouldn't budge because it is Toyota and he will always find someone to buy it as is which I get because these sell like hotcakes.
Also, as your first car, this is an excellent car on which to get some of your own wrenching experience. While the mechanic's quote really is quite reasonable for that work, you can save about half (or a little more) of that if you were to do it yourself (parts cost only).
Also, it's not all that uncommon to see folks cheap out with winter tires and only put two on the drive wheels, but it can make for some squirrelly driving due to the dramatically lower traction on the other two wheels. Just be aware and approach slick roads with some added caution so you don't end up putting the cart before the horse.
Yes, putting snows just on the front will have minor effect on handling but I did the same thing on my RWD truck and two mechanics tell me the difference will be small. Just practice normal defensive winter driving.
even better if they take care of the brakes and sunroof drains first.
He will also do the NYS inspection for me, so I'm guessing they'll have to tidy any leaks and stuff up before selling it.
The only thing is, since I'll be the third owner if I do resell this after like 3 years or so, I'm hoping to keep it for much longer but worst case I have to sell it, will the price drop significantly?
It sounds like you’ve gotten some pretty good advice from some of the old timers in here. I don’t know what your wrenching skills are but like @xwesx said, this is a good car to learn/hone them. You’ll never be sorry to have those skills even if it’s just knowing that a shop is being honest about what’s needed when you get quotes from them.
As for the NYS inspection, it’s a safety inspection and leaks won’t fail the inspection UNLESS it’s leaking brake fluid. They don’t let that slide at all.
Good luck and let us know what you do.
sure, it likely is worth less but probably not all that much. look at it this way. in 3 years say it is worth $5k. You will have maybe 10K in it now. that averages out to about $140/month. You can't get something new for close to that, and every car is going to cost something to own.
You will never find a car that age that doesn’t have some issues and if you did the price would be exorbitant. Don’t get “paralysis by analysis”. Good luck.
You left off at least one fluid on your list, like old washer fluid could cake up the squirter fitting.
I got the car! They changed the brakes for me so I don't have to pay anything extra and I am all good! I got it inspected again, just had to change the oil and add washer fluid but nothing else was needed. Excited to drive this baby around! Thanks for the help everyone!
Good luck!
Congrats. Hopefully you’ll have good luck with it.
Just remember to stay on top of the fluid changes. The oil change is a very good first step but don’t stop now. Yep, that washer fluid is a biggie.
Let us know how it’s doing in a month.
And yes I'll be sure to update here!
But after this fix, my VSC OFF light is flashing and the Traction control light is on. The button that toggles the traction control is not working, and I ran into this one off situation where I was stopped at a signal, and when I released the brake to proceed, pressing the accelerator didn't do anything. And the brake was not engaged and it was hard to push down as well. But the car moved like how it does when you put it on Drive. So I had to pull the handbrake, and restarting the car seems to have fixed the problem. I haven't had that happen again yet. This happened couple of weeks ago. One mechanic thinks it could be the abs sensor? I'm going to take it to another place to get a second opinion. The VSC OFF and Trac light are still on. I didn't have this issue before the SAS started misbehaving, any insights?
Some of the rubber around the windows and such are deteriorating but I guess that is given for the age of the car. But it isn't causing any problems like leaks when raining and such (yet). And also I've been getting a groaning sound when I turn the steering wheel, or press down the brakes since I got the car. But this is rare and I'm guessing happens when there is temperature fluctuations and it is cold.
But otherwise I haven't had any engine issues and what not. The car runs great and sounds great.
