Autoride Issues 07 Tahoe LTZ
littlecreeklittlecreek Member Posts: 3
edited March 2014 in Chevrolet
My air shocks will fill up but won't release once the load is removed. It's like riding a buck board untill I manually pull the hose off the shock to empty it. Then it will re-inflate to the proper level. Once I place a load on it...it does it all over again. Has anyone experienced this? Ideas?
Of course it never does it when I take it to the dealer!!
  • graphicguygraphicguy Member Posts: 14,070
    I've never had that issue with my LTZ. Sounds like the computer sensor isn't working correctly.
    Mine inflate when the load gets heavy and then deflate once the load is removed.
    Sounds like a trip to the dealer.
  • thebaldguythebaldguy Member Posts: 1
    I have a slightly different issue with my 2002 Yukon XL Denali. The sytem levels properly under normal driving conidtions and when I put a heavy trailer load on it. However, the vehicle slowly lowers in the rear after some time with heavy load and will only relevel if I turn the engine off and then back on. Only to lower again over time. Any experience out there?
