Buick Rendezvous Climate Control Problems
brookescar
Member Posts: 3
Has anyone had the problem of the AC clutch staying engaged all the time? Every morning the battery is drained and has to be jumped to start.
SUVs and Smart Shopper
when i have have face only selected with cool air or a/c on, it works fine and blows out a lot of air, only with the heater on face only does it not blow out much air....
any ideas?
For a while, a few days, the fan would not work on any speed. Then it would work on all speeds. Then it stopped working all together. Like I said, when the fan switch is turned to any speed, the air conditioner light will come on and the air conditioner will work. You can feel the difference in the air temperature when travelling fast enough. I first thought the problem was in the fan speed switch, but when I noticed the air conditioner light, I wondered if it wasn't the fan itself. I would do some exploratory checking, but I don't know how to remove the dash cover to get to the switch. Do you know how to remove the dash cover?
My '02 does not respond properly when I adjust the desired temp setting left knob.
The setting jumps all over the place; but mostly in the 85-90 degree range. Not a problem in the winter here in Phoenix but come summer I need to get that baby down to a more comfortable setting. Any idea what is causing this?
Dirty contacts on the module? This was the cause on an old PU I had in the early 90s. A quick clean of the module contacts and the system worked fine.
Any ideas? I'm not looking forward to tearing apart the dash to get at this thing.
Thanks.....
