Blazer/Jimmy Steering and Suspension Problems
So I didn't realize that I had to extract the steering knuckle to replace the lower ball joint... I already disconnected the tie rod end, removed the caliper and rotor, removed the upper ball joint, freed the lower(but it won't come out until the axle is out of the way. I have removed the 36mm hub nut, and the three 18mm back nuts, but the whole thing is free-floating. Is this all I have to do to remove the hub assy? Should I just put a big gear puller on and push on the spindle while pulling on the hub?
I also adjusted up the torsion bar on the left side by three turns which made a minimal difference. Im trying to resolve this so that I can set check the ride height and get this vehicle aligned. I work in an independent shop and see a lot of blazers and jimmys but have never come across this problem.
Also when I hit the brakes I hear a loud groan under the front of the vehicle. The front end is tight I was wondering if its possibly the front sway bar bushings creaking.
Any help would be greatly appreciated.
I have new OEM shocks all around and New tires. My problem is that the vehichle rocks back and forth either by the wind or any small or large bumps,rocks, holes ect. Front end alignment seems to be a tiny bit off. Does anyone have this problem or ever had this problem? Oh it is a 2wd 4 door. Thanks
