Honda S2000 Convertible Top
accelerator
Member Posts: 136
Any body have a leaking roof? Okay okay, I don't have an S yet and I'm researching... from the various posts I've read, I've never heard anyone mention anything about their tops leaking... Does your S leask? If so, how old is your S?
Does anyone have any experience in replacing the convertible top on a 2001 or earlier S2000? Care to share your experience and maybe recommend where to go to buy a new top? Should I get the glass instead of plastic and what does that entail?
Would sure appreciate whatever advice you might be able to offer.
-- Gary
Solo
I forget the exact wording but the maintenance like oil and so forth should be checked regularly. The S has a built-in maintenance minder system and when your oil gets down to 20% life left, the odemeter will change to 20% (or lower) every time you start the car. Also, depending on how aggressive you drive and the toe/camber settings of your particular S, you can expect to get about 12,000 miles out of the rear. My front tires are doing fine and I expect to get another 3k miles out of the back tires so I'm ahead of the average. BUT I suspect you are referring to items line timing belts (the S has a chain) and tune-ups. In regards to that sort of maintenance, I do believe 100k is right. There are some periodic changes such as tranny fluid, air filter, brake pads, that will have to be replaced/inspected more frequently (I don't want to make assumptions about your knowledge of cars).
does that help?
1. DO any of you drive your S2000's in the winter? How does the car handle snow?
2. Will the S2000 need to be parked in a covered space or will buying a car cover suffice?
3. I've been quoted $29,689 for an 08 S2000 by a local dealer in Albany. Is this a good price or must I bargain for a lower price?
I would really appreciate any advice that you can give me on this matter. Thank you.
Car cover or garage? Well, it has aluminum fenders and dents REALLY easily - had a nut fall out of a tree and dent my front left fender. Recommend garage.
I would not recommend your getting the S unless you have a second car for trips and a winter rat for the snow. Highway use? 4000 RPM/76 MPH gets VERY tiring.
Cannot hacve a conversation or hear the radio without pods or the headrest speakers. Just my opinion. I sold my 2004 after about 8000 miles - and it was our second car. GREAT sports car but just too much abuse on the ears and kidneys on trips. Good Luck.
The Price? Seems excellent. Paid $27,500 in 2004 for my certified used one with 4500 miles on it.
My only concern about having the S (or any softtop covertible for that matter) with large amounts of snow would be the weight of the snow on the top. I might recommend investing in a hard top if a covered structure isn't an option. I've seen them available for sale on various car forums like www.s2ki.com.
Also, I used mine as a daily driver and I love it.
Albany can get significant amounts of snow that lasts for days, if not weeks, with high temperatures for the day never reaching 32F. It is not only an occasional thing. As a daily driver, he indeed may be driving daily in sub freezing weather and snow/ice covered roads. I simply could not recommend it. You could always tell when it was spring in upstate New York - the Jags, the 'Vettes, the Porsches, etc, would all come out like Spring flowers. Otherwise you drove a winter rat. Ever see what an Upstate NY winter and the salt they put on the roads can do to a car?
When we moved to VA from NY I had a 10 year old Trans Am that was in showroom condition with 140,000 miles on it. In upstate NY - would have beena rust bucket. I would not subject my S2000 to that weather and those roads - abuse!
2. Get a covered space. As someone stated before, the body is made of aluminum and can dent.
3. If you're set on a new car, sure, $29.7K isn't bad. I don't know the market in Albany, so I'm not sure if you can get it cheaper. Pre-owned and used ones are better deals, though.
As for the roof and snow? Well, we moved back to NY - Manhattan, and I left my S2000 out in NJ at a friend's house covered with a car cover outside off the street. They had some pretty bad storms - 14-18" of snow and my car was buried under it. Never had a problem with the roof. It can hold a surprising amount of weight.
Sold her in 2006 - -had her upstate about 2 hours from NYC at a weekend house. Did not get to drive her much. Awesome car - white/tan with rear lip spoiler. Had it up to 152 in SC on I-77 once. The only car I have ever had capable of running at the redline at top speed. Very steady - 80-100 in 4th, 100-135 in 5th, 135-152 in 6th - and believe me with that overdrive that took a looooooooooooong time! That was the scariest part - how long it took - too many miles and exposed too long to police observation and/or radar.
Anyway, back to the S2000 and snow. While it might be possible, kind of out of keeping with its intended purpose and, IMHO, kinda dangerous.
A question concerning the top of my 2003 S2000. I bought it used and the previous owner did not maintain the top. I would like to recondition it to bring back (if possible) the original color. Any ideas?
I love the car - much like driving a go-kart.
rick
Bought the car used just over a year ago and the previous owner did not maintain the top. I would like to bring it back (if possible) to its orginal color. Any ideas how to do this? (its much too easy to buy a new one...)
Input most appreciated.
rick
http://www.s2ki.com/forums/index.php?showtopic=585993
Biggest problem with the top is an issue with ripping. Watch over the passenger side rear section for tearing. Honda will replace under warranty. Check www.S2Ki.com for info on the Honda S2000. And enjoy. Top down rocks.
minus49@aol.com
