-September 2024 Special Lease Deals-
Isuzu Rodeo Noise Problem
olsonsolsons Member Posts: 2
edited March 2014 in Isuzu
I have a 1995 Isuzu rodeo with 80K which makes a screeching noise only when I push in the clutch and when the temperature change ie"Hot to Cold" or when its damp. I just replaced the clutch and all its associated parts i.e." through bearing, flywheel, pilot bearing, disk, and pressure plate. I also replaced the master and slave cylinder. I don’t think it’s a clutch issue anymore. Any ideas.
  • olsonsolsons Member Posts: 2
  • enicoenico Member Posts: 1
    I'm having that same issue with my 97 rodeo 140K miles. When its hot outside and the air conditioner is running and I change gears, it starts to screech. And then every couple minutes or so it screeches on its own. If I shut off the air conditioner, it no longer screeches. When it does make noise I can feel the car pull a little.
    Does anyone know what this could be from?? The belt looks fine, the clutch is new.. Any idea??
  • hinermanhinerman Member Posts: 1
    I had the same problem on my 1995 Rodeo. Screeching when the AC was on, quiet when off. The problem was the harmonic balancer. The pulley for the AC is attached to the harmonic balancer and separated. THe screeching was the pulley rubbing on the balancer.
    Replace and problem solved.
    Bret
