Isuzu Trooper hesitation
I have an 94 trooper (160.000)...and have been having a hesitation problem at take off and in reverse. The CEL came on, but ran fine, so kept driving it. Then the hesitation started so took it to the mechanic and it was egr vavle, had that cleaned out. That stopped the hesitation for about a week. So I took her in again and was told the catalytic converter was clogged. Had them replace that, but still the hesitation. Any ideas? Please! I am not mechanically inclined at all...and have sunk a bit of money into it since I got it. Tired of going in and not knowing if I am being told the right thing or not because I am female and they want the $$$...Thank you
Try a fuel system additive Valvoline Synpower has a once in 3000 miles version that works well. I have used others too. The additive is to clean out the fuel injectors and possible help free up the top piston rings from combustion build up. .....Read the Labels very carefully!
