Cooling Fan Problems
cassielee1982
Member Posts: 1
in Pontiac
ok I am having problems with my 1995 Grand Prix Se Special Edition, the fans will not come on at all, even when you have the A/C on... We replaced the fuses under the hood on the passenger side and still nothing... it gets pretty warm it gets to about 213 or 214 and the fans still dont come on..(but the temp will drop back down to 210) what could be the problem here?? is there sensors that might need changed???
Another ? we added more anti freeze and followed what it said in the owners manual and started the car and now the check engine light wont go off.. whats up with that??? someone please help me I am used to older cars with out all this fancy computer stuff
It has a manual climate control system. It is not automatic or dual zone!
1) Fan motor does not work at setting 1, but does work at 2, 3, 4 and 5
Is this the resistor as I am reading here?
and
2) The air flows out of the floor, dash and defog vents and does not change no matter what the setting.
Where do I look to fix this problem? I am guessing it will have something to do with a direction panel of some sort?
