Land Rover Codes
ftorres00
Member Posts: 8
My Land R, discovey II, is showing all these codes, I have found some info in all except the P0734, I ahve the description for the code , but not the possible cause, can somebody help me out. Thank you soo much!!!
P073400 Slip too high between input and output shaft speeds in 4th gear Transmission Control Module.
http://solutions.3m.com/wps/portal/3M/en_US/3MAutomotive/Aftermarket/Products/Fu- el_Sys_Cleaner/.
For second problem, the transmission of your vehicle should be ZF 4HP22, it is a very old transmission, you can check the transmission oil level& quality first, especially notice any metal material in oil, that means transmission internal damage. good luck!
Any insight you have into the problem would be appreciated.
Matt
