Toyota Seinna break in period
Are you suppose to do something special on brand new sienna for initial xxx miles, i.e. not drive it over 60mph or not use cruise control etc???
Or there is no such thing in these modern vehicles.
This should be in the owner's manual?
We were told by our dealer that there was a break-in period, and that for the first 1,000 miles we should not use the cruise control or drive at a constant speed, rather we should vary the speeds at which we were driving.
Congrats to both of us.
What is the reason for no cruise or constant speed for 1000 miles?
They want you to vary RPMs the way you would through normal use throughout it's life.
Just put a piece of tape over the cruise button for now, so it doesn't happen again, it's easy to forget!
Even if you use cruise, the engine revs go up and down unless you have straight level road which hardly is the case. Even level roads their are small ups/downs and turns... and with this, revs got to change... Speed will stay the same.... wheels will turn at same rat... you got the point..
When you're not using cruise, then you rev would also change..
So, my point... go ahead enjoy it and not to worry about it. Only time you can possibly will constant revs if you parked it in your driveway and let it run idle.
im new on here so responed back....in any way that is easy for me to reach
