-July 2024 Special Lease Deals-
Chrysler LHS Maintenance and Repair
shadetree11shadetree11 Member Posts: 2
edited September 2014 in Chrysler
The power steering rack on my LHS makes a whining sound when turning. This only happens when the outside temperature is over 70 degrees and the car is at operation temporature. The rack was replaced about 3 years ago and started making the noise about a year after it was installed. At that time I had the system flushed to replace the ATF3 fluid with ATF4 fluid to try and stop the noise at which time they discovered the filter in the reservoir bottle was all but clogged so they replaced the bottle. Any recommendations on what I can try other than living with it or replacing the power steering rack again?
    patrickrrpatrickrr Member Posts: 1
    I have a 2000 LHS that does the same exact thing. It has to be humid then it starts. I have flush the power steering fluid as well. To me the sound it more at firewall. I think the steering gears at the firewall must not keep moisture out. If I could crack the thing open I would try to spray some lube in it.
    ricfloresricflores Member Posts: 2
    I have a 94 LHS, that keeps going into fail safe mode. Basically it keeps getting stuck in 2nd gear. It's the same as everyone else, it will drive good for a little while then, boom; it's in 2nd again. Does anyone know what the solution to fixing this is? From reading everyone else's post, they are spending lots of money and the problem still exist. Frustrated car owner here, help if you can. Thanks.
    shaliloglushaliloglu Member Posts: 36
    I have 99 LHS. A couple of years ago I started smelling fuel in the car, outside the car. They had a recal to replace O-rings? which made the fuel smell disappear. Now it ihas been for a while. Wondering if it is the same issue if I do not know what these O-rings are , what they do etc.
    Any info/advice someone can render I would love to hear . Thanks in advance.
    pbald007pbald007 Member Posts: 1
    The O rings are basically rubber gaskets that fit around the fuel injectors (cost about $6 each) that seal the fule form leaking out. Contact a Chrysler dealer to have you car fixed at no charge under the recall notice.
    lhs976lhs976 Member Posts: 10
    i have a 2001 and it does the same thing. i brought it to the dealership and they sprayed it for me. seems to have done the trick.
    troubleshoot1troubleshoot1 Member Posts: 1
    I had the same problem with my 94 LHS and here is the unusual outcome. I don't know if it's a 94 year only problem but this trans, as you probably know, is electronically controlled by the powertrain computer and is connected via a large wiring harness which plugs into the top of trans. Pull the connector and harness out and take off the outer covering near the connector, I found Chrysler had wraped the wires with adhesive tape that somehow disolved the plastic coating on the wires allowing them to touch occasionally puting the trans into default limp-in mode. All you should have to do reisulate the wires and be good to go. I hope this helps you and saves you much time and grief. Bill
    lennonfan74lennonfan74 Member Posts: 2
    We need to replace a cradle to body isolator bushing and cannot find out anywhere how hard it is to do, or how to do this. We have the Chilton but it only shows how to replace the stabalizer bar the bushing needing replaced is on the front side of the passenger tire.Does anyone know if this is something that can be done wiothout any special tools and paying too much for labor.thank you
    bug5bug5 Member Posts: 2
    I have a 2001 LHS with 72,000 miles. My question is when the vehicle sits overnight or for several hours their is a slight "clicking" sound from the top of the engine but then goes away very quickly. If the engine is hot and you turn the engine off and then restart their isn't any noise - only when it's cold. I believe the lifters which I think are hydraulic are leaking and have to reprime when the vehicle starts cold. So far no damage I am aware of has occured but I know I need to replace these items or get it fixed. What else could make this noise and is it expensive to fix.
    leathersleathers Member Posts: 1
    On my LHS my fuel gauge is always reading Empty with the fuel light on with even as much as a half tank of gas in it. I did not know if it was a fuel economy problem like tuneup, or electrical problem, or if the needle just broke. I was on the high way and it came up a read the gas but then went right back down to E, this is the worst time to not know how much gas you have, help please..">
    jayriderjayrider Member Posts: 3,602
    13 years is pretty good for a fuel gauge. Unless you are a mechanic, go to a reliable garage and have it diagnosed.
    marcdubiousmarcdubious Member Posts: 2
    Can anyone help me with my door problem my driver side door will only lock manually I can lock it with the key or push the lock by hand to lock and unlock it. but the power switch for the locks on the driver side works but only for the other three doors. It will not operate the drivers door Also when I go to unllock the drivers door and open it the enterior lights do not come on but they come on when I unlock and lock the passenger (and if you haven't guessed I do not have the remote entry key pads
    tsurnicktsurnick Member Posts: 42
    I would first check fuses, but i dont think that is the issue since your other three door locks are working. Your lights should be controled by a switch near the hinge of the door.when you close the door, it shuts the lights off and such. That might also link to your locking problem. i would look there first. when you open the door all the way look for a push button switch with a rubber cover around it. thats what mine has on it. with the door open your lights shoud be on. you can unscrew the switch and see if it is connected. if not, you need to look for the wire in the hole where it came out of. you can even try a toggle switch and see what happens just to test. try that and let us know what happens.
    hope that helps..
    tim
    jeffbujoldjeffbujold Member Posts: 2
    My 99 chrysler Lhs shutters while driving or stalls when ideling when it reaches operating temperature , then after that, it runs fine. What do you think is wrong?
    smokedoggsmokedogg Member Posts: 3
    I have been having the same exact problem. Driver side door. Been trying to figure this out for awhile now. My door lock switch was all jacked up so I thought thats all that needed to be fixed. Well, that wasnt it. Fuses - Relays are all okay, leaving me confused. Was anyone able to resolve this issue. Thanks
    I had the same problem and one of the guys on here told me to look at the Idle air control valve. I got one of those books from the auto parts store that tells all about the car and looked at a picture of it and where it was on the engine. it was easy to replace. I also replaced the MAP sensor ( i dont know what it does) but it helped make the car run better too.
    Hope that helps.
    mendyusamendyusa Member Posts: 6
    05 Town and Country Ltd doors do not lock or unlock using switchs on doors or key fob. Alarm beeps however. Cleaned posts on fuse 10D with pencil eraser and re-inserted. Problem fixed. Fuse 10D is hard to find as it is not included in the diagram on the fuse boxes inside cover. Look for it in the lower left quadrant of the box as your leaning over the fender. It is labeled by the fuse. Black 10D on black plastic look real close.
    Oh wow I hope its gunna be this easy. Is it a fuse with 2 prongs, or the relay with 5 prong things? Also, is it the box under the hood or in the quarter panel inside the car? Cause I couldnt find anything labeled 10D. If i could post or somehow send you the 2 pics I got of the fuse boxes it would probably be more helpful. Thank you very much for replying to me. I didnt think anyone was ever going too. Thank you much.">
    Gauges, air conditioning, message center NOT working.
    I just found number 14 fuse (5 amp) blown. I replaced it and everything came back on momentarily and then the fuse blew again. I am assuming there is a short. Where do I look first? I got 3 trouble codes also.
    1. Code 77 Speed Control Power Relay circut is open or shorted
    2. Code 21 Problem with Oxygen Sensor Signal Circuit, Sensor Voltage to computer not fluctuating.
    3. Code 12 Problem with the Battery Connection. Direct Battery Input to controller Disconnect within the last the last 50 ignition key-on cycles
    any Ideas?
    wg9966wg9966 Member Posts: 1
    I have a 1996 Chrysler LHS that for the past few months have been getting increasingly worse. The problems are (1) Rough/high/poor idling, (2) Incorrect Idle speed/stalling, (3) stalling and jerking when coming to a stop at traffic lights. Before I replaced my IAC valve/motor one week ago it had never cut off when I stopped at a stop light (which it did yesterday), also before I replaced my IAC valve/motor it idled at close to 4000 rpm when in park with the engine running, now it idles at 2200 at park with the engine running .Also I want to mention that my gas peddle have been sticking for as long as I can remember (even before my engine light came on at the beginning of my idle control problems). When my engine light came on in the beginning I had it checked for free at AAA Auto and they just told me the code and not what might be wrong with it. The code I received was “Fault Code P1294-Target Idle Not Reached”! Not wanting to spend the $80.00 to have Pepboys tell me what may be wrong and then another fee to fix it I decided to just have the IAC valve/motor replaced. I'm behind now $105.00 because the problem still is not fixed! After some more research I was wondering could it be the “EXHAUST GAS RECIRCULATION VALVE”? Also Is the IAC valve/motor another name for the “throttle control valve?” If not could my problem be with/in the “THROTTLE CONTROL VALVE?” Any help would be greatly appreciated!
    You had the same problem I did. I replaced the IAC valve, Then the MAP sensor (which didnt do much) then I replaced the THROTTLE POSITION SWITCH. I think that is the one you need to look at next. I helped alot for me. On my 94 LHS it is on the left of the throttle body towards the passenger side of car if you were standing infront of the car. Its real easy to replace and i think it ran about 30 bucks or so. I have the 3.5 motor, i dont know if thats the same as yours though. You may want to look into replacing the intake manifold gaskets. it all comes in a kit but i cant remember how much it costs. They were real easy to do but it took me and a friend about 7-8 hours. we were in no hurry, so you could probably do it faster if you wanted to. I did Those three things and then did the intake manifold gaskets and it runs great now. If you see posts from Tuscanskipper on here, you should send him an email. He seems really knowledgable when it comes to LHS stuff and has helped me alot. He was the one who told me about the intake manifold gaskets. you should be able to do a search for those posts on here about that as well. good luck.. if you have anymore questions, feel free to reply back..
    tim
    linie5linie5 Member Posts: 1
    My LHS keeps stalling out on the road, we pull over it starts right back up, no hesitation on starting again, will do it here or there, no rhyme or reason. We just replaced both oxygen sensors, anyone have any ideas, there is no codes coming on.
    96lhsmatt96lhsmatt Member Posts: 3
    i replace my sub frame bushings in the back naapa has the bushings for 75 a peice it was a 22mm that i used to do the back the front should be easier the dealer is charging 150 per bushing
    i have replaced the cam shaft positioning sensor and the crank shaft positioning thinking that i would get a spark still nothing im about to buy the coil pack should this fi my problem or is there more i need to know
    cooncoon Member Posts: 5
    I just bought sub frame bushings (isolators) from O'reilly's for 56.00 a pair
    need to replace sub frame bushings (isolators) does anyone know if special tools r needed and if its a big job?
    icanfixitnaticanfixitnat Member Posts: 3
    Did you get the problem fixed?
    There was a recall to fix the faulty o-rings on my 1995 LHS. Dealer did the fix 4 years ago. All was well for a while and now same problem has come back.
    Dealer says they will not fix it again since the recall was done. Apparently they are only allowed to do it once.
    Independent mechanic checked out the problem and says fuel rail and oring leaking..
    my questions is: should the dealer/chrysled corp. be help responsible to fix this issue again OR is once done all they are required to do.?
    If you know the answer please help and post.
    what other recourse do I have.? How do I contact Chrysler to request assistance.?
    I am looking at a $500+ bill on this... thanks in advance.
    just_me2just_me2 Member Posts: 3
    edited June 2010
    the past few days my 95 lhs transmission has been acting crazy, day 1 I left the house and noticed that it was'nt changing gears, 'I thought it was 1st' but after it sat for a while and i would drive around the block i would feel it shift from low to 2nd but just stay there. my buddy checked it-fluid was fine, he tried driving it to 45mph and shifting to park then to drive but that did nothing, day 2 it drove just fine for many trips, then i felt a little jerking in the tranny then it went back to 2nd and just stayed there. day 3 same thing just fine for half the day, but on the freeway doing 70 it went into a neutral with no gears catching until my speed dropped to about 40 then it jerked and went back to 2nd.. i will change the fluids and filter when i get some dough.. any ideas if that does not help? thank you in advance.. sorry the note is so long.
    grundosgrundos Member Posts: 2
    I purchased a 1994 Chrysler LHS that had not been driven for a few months. The seller said they had let it run for a while on the regular basis.
    The problem...when I drive for ~10 miles in traffic, the car stalls at a stop. There is no sputtering or unusual signs. It simply turns off. This only happens when it has been at a stop for at least 10-15 seconds. It takes about an hour to start up again.
    I've searched the forums for similar problems, but every other post i found has stated their car started up again with no issues.
    I've only tried changing the fuel filter, as I'm not very handy with cars. I wanted to gather information to see if this was a problem I could fix myself, or if I'd be better off taking it somewhere.
    I would try changing the throttle position switch and the Idle air control valve. I think one was 30 dollars and the other was 20. they are both easy to switch out. I had a similar problem with my LHS and that fixed it.
    I have the same problem with my 94 LHS stalling out. It only does it when i am stopped at a light or sitting still for a few minutes. any ideas?
    My LHS does the same thing. It seems to be happening more often when its cold outside. I found that if I pull over and shut the car off and restart the car then put it into gear, most of the time it is back to normal then.
    I have already changed the filter and the fluid ( which was pretty bad) but it still does the same thing mainly when it is cold.
    yeah, ive been doing something that works more often than not, as soon as it 'limps' i just throw it in neutral turn the key off, wait about 5-10 secs restart and put it back in gear.
    - DISCLAIMER -
    Do not attempt, I am a professional driver on a closed course. LOL
