M45 Road Noise
mytymemytyme Member Posts: 1
edited March 2014 in INFINITI
Just picked up my new M45 yesterday.
On my way home (while driving on concrete) an annoying road noise that was not present on the other M45's I demoed. Is it the tires, is it a design problem? Anyone had any luck with some of the noise damping products? Thanks.
  • ghstudioghstudio Member Posts: 972
    it's most likely the road surface...and how it interacts with your tires. If you change your tires, you may quiet that stretch of road, but then you'll hit some other stretch where you get new noise.
  • james27james27 Member Posts: 433
    I spent around $900 at a stereo shop for some Dynamat...it helps. I had the entire floor done and the trunk plus the doors.
