Ford Edge Heads Up!!
A friend from work just picked up her EDGE SEL. Two days later she took it back to the dealer to have the remote start installed. On the way home her brakes locked up and the stabillity control indicator went nuts (flashing like a strobe light). Well after finally getting back to the dealership on the back of a tow truck, the dealer told her it wa the BOS (brake on/off switch) that as he claims they have had a problem with on the early production EDGE. The new ones have the problem already corrected. BUT.... of course no-one in the country has the part so she has been without her EDGE for almost a week! Might want to do some preventative maintenance and ask your dealer if your EDGE falls into the "early production" class and get the switch replaced.
Me, I haven't had any problems with my EDGE after 5K (knock on wood!!!). Only complaint is a rattle in the rear passenger side that I can't pin-point. Any body else have that issue?
Sounds like one to watch - if you hear a follow-up from her, please let us know.
